[Qgis-developer] link for msys don't work (compile qgis inwindows)
Alberto Asuero Arroyo
albertoasuero at gmail.com
Tue Jan 20 09:08:45 EST 2009
Hi Marco,
I could compile with success but now I'm trying to prepare MS-Windown but
the pythonQT link doesn't work.
I've been looking for the same version (PyQt-win-gpl-4.4.2.zip) and I found
it, but when I do the make many errors are reported.
"qgis python previous declaration `long int InterlockedCompareExchange"
it's same two libraries who define the same function
any ideas?? thanks!
On Wed, Oct 22, 2008 at 9:17 AM, Marco Pasetti <marcopstt at gmail.com> wrote:
> Alberto,
> Thanks tim, but it's the file which I had found because there is a problem
>> with the geos library...
> " You're using deprecated header io.h. Please update your sources
>> according to new layout of GEOS headers and namespace "
> The file install talk about some directories that is not present then I
>> think it's not the file correct.
>> I'm going to read the section which godofedro talk about
> check out the trunk and read the documentation for MS-Windows
> (qgis/ms-windows/README.html)
> referring to the above documentation, follow the instruction from point 1
> to 9 (included)
> Regards,
> Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090120/6edfdd50/attachment.html
