[Qgis-developer] Build plugins for use with Mac binary
Peter Ersts
ersts at amnh.org
Wed Jan 21 11:01:37 EST 2009
Howdy William. Thanks for the quick response.
William Kyngesburye wrote:
> It looks like maybe something went wrong in Tom's 1.0 compilation so
> that it dropped the version numbers. So there is a version mismatch
> between your plugin and Qgis.
> Also, you say you are using my frameworks - GEOS and GDAL, it looks
> like? Then are you using install_name_tool to change the library
> references in your plugin? Same problem, though backwards.
Yes, just downloaded your frameworks again today and yes I am using
install_name_tool to change the reference to match the QGIS binary
distribution.
> I build my GEOS framework with the C++ and C APIs combined, thus they
> can't have the two different version numbers, so I use an arbitrary
> numbering system. I *think* Apple's runtime linker compatibility
> versioning doesn't operate at all across major versions, forwards *or*
> backwards (at least, I've had problems in the past trying to do so).
I don't think it does and I want to say that that is the same across
minor numbers as well. When I first started trying to compiled for OSX I
my QT version was one minor version number different (newer) and the
plugin would not load. Once I changed Qt versions it loaded up just fine.
> Well, since you're using my frameworks to build your plugin, and your
> own Qgis, try it out on my Qgis 1.0? No need to change the library
> paths for GEOS or GDAL.
I tried the version from your site Qgis 1.0.0-1 for Leopard. It
immediately crashed at first. Seems that the GDAL 1.6 framework requires
postgres, though it is not listed as a dependency. Once I installed the
postgres framework qgis loaded but when I add my plugin it crashes again
There is still a different in the GEOS version numbers. The north arrow
plugin shows GOES lib compatability version 4.0.0, current version
4.1.0, when I build with your GOES framework (
GOES_Framework-3.0.3-1.dmg ) that is online, I get compatability version
4.0.0, current version 4.0.3
> If you just want to make sure it will work on distributed Qgis
> binaries, Tom may have to try rebuilding to get those version numbers
> in there.
aye, it would be good to hear if any other folks have had trouble.
Thanks for you time.
-pete
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: Home Office (518)-632-4745 or NYC Office (212)-496-3488
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Quantum GIS Raster Development Team. Visit http://www.qgis.org
to learn more about QGIS, a free and open source desktop GIS
Open Source,
...evolving through community cooperation to change the world bit by bit
