[Qgis-developer] Build plugins for use with Mac binary
William Kyngesburye woklist at kyngchaos.com
Thu Jan 22 10:16:48 EST 2009
PS. Something occurred to me about distributing a plugin binary - Qgis
isn't properly setup for 3rd-party plugins.  This requires (on OSX,
but not necessarily other platforms):
- an external plugin dir, like in the user's home folder.  It's not a
good idea to install 3rd-party plugins inside an application's bundle
on OSX.  I don't know if Qgis has this option, but it's dependent on
the next requirement.
- it can handle an arbitrary location for the Qgis application.  Users
can and will move and/or rename the Qgis application.
This relocation flexibility has a couple parts:
- the plugin is compiled with the -bundle flag, which is true now
- the plugin does NOT reference any library inside the Qgis
application package.  And there's the problem.  Normally, the -bundle
flag gets around the problem of linking the main binary of a program
(qgis) because that binary is assumed to be loaded already, but Qgis
plugins also link the Qgis *libraries* and the Qt frameworks.
I'm not sure if the -bundle flag works for secondary linked libraries
(ie qgiscore as linked from qgis), but I think it should.  It would be
worth trying to compile your plugin by linking only GEOS and GDAL, no
qgis or Qt, something like:
-bundle -undefined dynamic_lookup -framework GEOS -framework GDAL
This would also solve the problem of the incorrect library versions in
the all-in-one build.
Heck, if we figure that qgis also loads the GEOS and GDAL libraries,
you could also leave those out, then there wouldn't be the GEOS
version problem.  You just have to assume that builds of Qgis will use
the same GEOS and GDAL major versions, which could be dangerous.
(The safe way would be to compile separate plugin binaries for each
Qgis distro.)
On Jan 21, 2009, at 2:25 PM, William Kyngesburye wrote:
> But really, it shouldn't matter what Qgis itself uses for extra
> dependencies - external libraries or frameworks, or bundled.  And
> it's not really up to Qgis to provide these itself (bundled).
> You can make your plugin with whatever dependencies you like,
> independent of what Qgis uses.  You just need to make sure that they
> are available somehow, either packaged with the plugin (or linked as
> static libraries, which is good for oddball libraries), or in Qgis
> (not recommended, except for Qt and Qgis libraries) or separately
> (like my frameworks).
> Just build the plugin, ie with my frameworks, and don't change those
> references, just the Qgis and Qt references.  Though there is
> something wrong in the all-in-one build with the Qgis library
> versions, which should be fixed for it to work at all.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
