[Qgis-developer] debug/verbose mode?
William Kyngesburye
woklist at kyngchaos.com
Wed Jan 28 21:18:38 EST 2009
That's the gcc debug binary, I think. I don't want to run Qgis thru a
debugger (I don't know much about it anyways). I just want to see the
QgsDebugMsg() messages.
On Jan 28, 2009, at 7:46 PM, John C. Tull wrote:
> AFAIK, you have to build your binary with the debug option. You can
> do this with 'ccmake ..' from the build directory. You will see an
> option near the top for 'CMAKE_BUILD_TYPE'. Set that to Debug. You
> can also do this manually as an option with cmake or ccmake as '-D
> CMAKE_BUILD_TYPE=Debug'.
> John
> On Jan 28, 2009, at 9:23 AM, William Kyngesburye wrote:
>> I knew this once - how do I start Qgis OSX app in debug mode (to
>> get extra messages in the log, not a gcc debug binary)?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
