[Qgis-developer] QgsVertexMarker modified class: Plot moving points
over a map at fixed rate
Luca Pascale
pascale.luca.it at gmail.com
Thu Jul 2 06:29:10 EDT 2009
Hi all,
I have made a py plugin that plot points at a given position over an
underlying map.
At a given rate (1 time per second for example) the points change position
and move over the map.
I have used QgsVertexMarker to do this.
Now I am trying to plot instead of the "icon" make available by
QgsVertexMarker class, a custom image loaded from a file.
SO I modified the class in the following way:
- add ICON_CUSTOM to the enum
enum IconType
ICON_NONE,
ICON_CROSS,
ICON_X,
ICON_BOX,
ICON_CUSTOM
- add the method
void QgsVertexMarker::setIconFileName (QString fname)
mFileName=fname;
- modify the QgsVertexMarker::paint
void QgsVertexMarker::paint( QPainter* p )
qreal s = ( mIconSize - 1 ) / 2;
QPen pen( mColor );
pen.setWidth( mPenWidth );
p->setPen( pen );
switch ( mIconType )
case ICON_NONE:
break;
case ICON_CROSS:
p->drawLine( QLineF( -s, 0, s, 0 ) );
p->drawLine( QLineF( 0, -s, 0, s ) );
break;
case ICON_X:
p->drawLine( QLineF( -s, -s, s, s ) );
p->drawLine( QLineF( -s, s, s, -s ) );
break;
case ICON_BOX:
p->drawLine( QLineF( -s, -s, s, -s ) );
p->drawLine( QLineF( s, -s, s, s ) );
p->drawLine( QLineF( s, s, -s, s ) );
p->drawLine( QLineF( -s, s, -s, -s ) );
break;
case ICON_CUSTOM:
QPixmap pixmap(QSize(22,22));
pixmap.load(mFileName);
p->drawPixmap(0,0,pixmap);
break;
- update the binding file .sip
The problem now is that the icon (png file) is not plotted correctly until I
refresh the map canvas.
See the attached images.
notcorrectvisualization.png is what I obtain on the screen
and
correctvisualization.png is waht I obtain after pushed the refresh button.
Any suggestion to solve ??
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090702/53826627/attachment.html
