[Qgis-developer] qgis 1.2 findings
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Jul 5 17:38:30 EDT 2009
Hi Richard,
On Thu, 2009-07-02 at 23:01 +0200, Richard Kostecky wrote:
> Thanks a lot,
> I have already found system ho to reproduce and probably fixed this
> error. I'll test it with this layer and if successful send it to
> Martin.
Still I have to open the ticket about this problem or it is already
being patched?
thanks
-- Giovanni --
> On Thu, Jul 2, 2009 at 2:17 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com> wrote:
> On Wed, 2009-07-01 at 07:59 +0200, Richard Kostecky wrote:
> > Hi I still wasn't able to reproduce this issue (error in
> simplify
> > feature).
> > If you have any layer on which to reproduce, please send it
> to me and
> > I willl have a look on it.
> > Thanks
> > Richard
> > PS: Sorry for late answer but I didn't had much time lately
> since I
> > have exam period in school.
> Hi!
> I was able to reproduce the error* 10 times out of 10 with the
> vector
> you can download at this link**. Consider that is a "complex"
> polygon,
> but I reproduced the error also with very simple ones.
> These are my observations:
> a) with this test layer (that has many nodes), once clicked
> with the
> "simplify feature" tool, the slider takes a few seconds before
> show up.
> Maybe this is physiological delay, maybe is possible to do
> something.
> b) add the layer, click with the simplify tool, move the
> slider, put the
> slider to the initial value, click ok -> qgis crashes
> c) add the layer, click with the simplify tool, *don't* move
> the slider,
> click ok -> qgis do not crashes
> then if you click again with the simplify tool, move the
> slider, put the
> slider to the initial value -> qgis do not crashes
> d) when you use the simplify tool as in c), then you exit the
> editing
> mode, qgis asks if you want to save the changes -> this do not
> make a
> lot of sense as no changes were made.
> e) I noticed also the following: take the "majrivers"
> shapefile (you can
> find it in the qgis demo data), and test the simplify tool. On
> some
> features it works fine, on others it behaves like the above
> description
> and on others is enough to click with the tool on the feature
> to crash
> qgis.
> Platform is Ubuntu 9.04 and QGIS rev. 11005
> Hope this can help
> -- Giovanni --
> Fatal: ASSERT failure in QVector<T>::operator[]: "index out of
> range",
> file /usr/include/qt4/QtCore/qvector.h, line 331
> Aborted
> http://www.faunalia.pt/downloads/dist_evora.tar.gz
