[Qgis-developer] Edit tools: planned "rotate feature" and
"draw rectangle" ?
Agustin Lobo
alobolistas at gmail.com
Wed Jul 15 09:14:37 EDT 2009
For planing low height aerial campaigns with small format cameras. It's
useful having a rectangle of the size
of the planned footprint (of a single image or of the length of a flight
line and the width of an image) and moving it and orienting it to
accommodate the features that you want to cover.
Also, defining a rectangle to clip an image (which I use to simulate the
result that we are supposed
to get if appropriate imagery is available, i.e. a previous
regular aerial photography)
In general, this would be useful for designing field sampling schemes by
locating rectangular plots of a pre-defined size.
Agus
Andreas Neumann wrote:
> Hi Agus,
> Marco Hugentobler is currently working on a point-rotate tool for rotating
> SVG symbols.
> Are you sure that a rotate function really makes sense for line and
> polygon features? I doubt it. What would be the use-case?
> Andreas
> On Wed, July 15, 2009 9:15 am, Agustin Lobo wrote:
>> The current "Move feature" tool does not allow rotation,
>> is this planned in the future? Also, are there plans
>> to include drawing an initial rectangle of a given size (may be other
>> simple
>> geometric shapes
>> as well) that could be interactively refined afterwards?
>> Thanks
>> Agus
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
