[Qgis-developer] grassplugin compile error - svn trunk 11159 Ubuntu
8.04
Jamie Adams
jaadfoo at gmail.com
Thu Jul 23 14:17:07 EDT 2009
I've been getting grassplugin compilation errors on Ubuntu 8.04 the last few
days after several svn trunk updates. Is this just work in progress? If
not, what am I missing?
[ 83%] Generating ui_qgsgrassmodulebase.h
[ 83%] Generating ui_qgsgrassnewmapsetbase.h
[ 83%] Generating ui_qgsgrassattributesbase.h
[ 83%] Generating ui_qgsgrassregionbase.h
[ 83%] Generating ui_qgsprojectionselectorbase.h
Scanning dependencies of target grassplugin
[ 83%] Building CXX object
src/plugins/grass/CMakeFiles/grassplugin.dir/qgsgrassplugin.o
In file included from
/usr/local/build/qgis_unstable/src/plugins/grass/qgsgrasstools.h:19,
from
/usr/local/build/qgis_unstable/src/plugins/grass/qgsgrassplugin.cpp:27:
/usr/local/build/qgis_unstable/build/src/plugins/grass/ui_qgsgrasstoolsbase.h:
In member function 'void Ui_QgsGrassToolsBase::setupUi(QDialog*)':
/usr/local/build/qgis_unstable/build/src/plugins/grass/ui_qgsgrasstoolsbase.h:58:
error: 'class QTreeWidget' has no member named 'setHeaderHidden'
make[2]: *** [src/plugins/grass/CMakeFiles/grassplugin.dir/qgsgrassplugin.o]
Error 1
make[1]: *** [src/plugins/grass/CMakeFiles/grassplugin.dir/all] Error 2
make: *** [all] Error 2
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090723/d44aaf3d/attachment.html
