[Qgis-developer] Python Version
Water Guy
water.guy77 at gmail.com
Tue Jun 2 15:28:44 EDT 2009
Thank you for your input.
Maybe I have another problem then. If I open the Terminal and type:
python2.6
>>> import qgis.core
I get:
File "<stdin>", line 1, in <module>
ImportError: No module named qgis.core
However, if I do the same with python2.5 it works fine, and I can go
on to write a shapefile, etc.
Any idea what would cause this? I am using Ubuntu Jaunty.
Thanks,
Matt
On Tue, Jun 2, 2009 at 3:11 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Matt,
> On Tue, 02. Jun 2009 at 14:57:44 -0400, Water Guy wrote:
> > Does anyone have any suggestions for handling this situation? Can the
> > QGIS bindings be made to work with python2.6? Also, if I can get this
> to
> > work using python2.6 is there a way to make a QGIS plugin use version
> 2.6?
> The ubuntu jaunty packages are build against python 2.6. I didn't hear
> about
> any problems with that yet, so I suppose there is no problem with qgis and
> python 2.6.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090602/d773c510/attachment.html
