[Qgis-developer] R plugins
Volkan Kepoglu vkepoglu at gmail.com
Wed Jun 3 10:23:22 EDT 2009
which one is more appropriate?
a new plugin (like spqr2) OR spqr plugin will have both rpy and rpy2 feature
both of them fits me but i never used svn.
On Wed, Jun 3, 2009 at 5:15 PM, Barry Rowlingson <
b.rowlingson at lancaster.ac.uk> wrote:
> On Wed, Jun 3, 2009 at 3:07 PM, Volkan Kepoglu <vkepoglu at gmail.com> wrote:
> > Hi,
> > yes, it is true. sda4pp plugin uses rpy2 (2.0.3)
> > very interesting error. I have never seen before.
> > if i have time, will i upgrade the spqr to use rpy2, if Bary do not mind?
>  It's released under the GPL, so I don't have any say in the matter
> even if I did mind :)
>  But the problem is that we need to keep rpy-1 and rpy-2 versions
> going, since rpy-2 isn't that mainstream yet (by which I mean "isn't
> in the ubuntu repositories" :) ).
>  So I'm not sure what the best solution for developing and deploying a
> rpy-2 compatible version of spqr would be. Currently I'm thinking I
> need to create a new plugin, lets's say called spqr2, in my bsrplugins
> repository, and give you (Volkan) commit access (which probably means
> you get commit access to all the bsrplugins, but that's okay), and
> then I just add spqr2 to my qgis repository for deployment. The info
> for spqr2 will make it clear that it is rpy-2 compatible.
>  We could just create a new SVN branch for it, but currently my code
> for building the repository from SVN doesn't handle that - it only
> exports 'trunk' (I think). In effect creating a new plugin is like a
> new branch anyway, since all the bsrplugins sit in the same SVN space.
> Barry
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
Ankara, Turkey.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090603/52c6da58/attachment.html
