[Qgis-developer] Patch for Table Manager (ver.0.17) - python
plugin
Volkan Kepoglu
vkepoglu at gmail.com
Thu Jun 4 07:13:28 EDT 2009
this patch is only for to fix the error, not to refactor the code.
i tried to change the code as minimum as possible.
os.path.join(Path, Filename) is more appropriate, but if the code is working
without using proper built-in function,
that is also fine for me.
volkan.
On Thu, Jun 4, 2009 at 1:55 PM, Barry Rowlingson <
b.rowlingson at lancaster.ac.uk> wrote:
> > srcPath += '/' + srcName
> > if self.writeToShp(tmpDir+'/'+srcName+'.shp',
> self.provider.encoding())
> > QgsVectorFileWriter.deleteShapeFile(tmpDir+'/'+srcName+'.shp')
> > QFile(srcPath+'.dbf~').remove()
> > if not QFile(srcPath+'.dbf').rename(srcPath+'.dbf~'):
> > shutil.copy(tmpDir+'/'+srcName+'.dbf', srcPath+'.dbf')
> ouch ouch ouch!
> If you need to do file path manipulation in python then it's
> generally better to use functions from the os.path module - it handles
> OS-specific things like / and \, splitting dir/filename from paths,
> creating canonical paths, resolving symlinks (if your OS supports it)
> and all that.
> Note that os.path tends to fail if you feed it QStrings, so convert
> to python strings beforehand, or maybe use methods from QDir -
> actually, that's probably a better idea! QDir has methods for these
> sort of things too. Concatenating strings for files, especially adding
> slashes or backslashes, can get painful when you go across platforms.
> Barry
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090604/ea5a7dcd/attachment.html
