[Qgis-developer] Node tool
Martin Dobias wonder.sk at gmail.com
Tue Jun 9 18:31:39 EDT 2009
On Mon, Jun 8, 2009 at 12:10 PM, Martin Dobias<wonder.sk at gmail.com> wrote:
>> The new option "do not show vertex marker" is very nice, but when you have loaded many layers, you do not see or know if one or more layers are toggled in editing mode. In minimum the editing layers should be marked as "in editing mode" in the layer list. In former versions, until 0.8 I believe, the layer in editing mode were marked with a hashed box around the layer name.
> Yes, I remember that functionality :-) There were overlay icons for
> "in overview" and "editable" states of a layer. From a brief look at
> the code, I've figured out that the code for it still exists
> (QgsLegendLayer::updateIcon), however some plumbing that would trigger
> the update is missing.
Starting from r10895 there's a different icon in layer list to
indicate that a layer is editable.
Hope that helps!
Martin
