[Qgis-developer] New plugin: SDA4PP (Spatial Data Analysis for
Point Pattern)
Volkan Kepoglu
vkepoglu at gmail.com
Thu Jun 11 03:25:46 EDT 2009
Hi Paolo,
the error is fixed. current version: 0.113
changing the name of the plugin, i will consider.
thanks for your input.
regards,
volkan
On Thu, Jun 11, 2009 at 9:22 AM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Volkan Kepoglu ha scritto:
> > *Dear to all,
> > The plugin performs analysis on point pattern spatial data. It uses
> > spatial analytical structure of R. The plugin communicates with R
> > through RPy2.
> Hi Volkan.
> Spotted a new bug. When selecting ggobi from the menu, without any layer
> loaded, I get:
> NEW LOGGING | 11.06.2009 08:18:12 - starting from SDATool-initGui.
> CLASS NAME | FUNCTION NAME - MESSAGE
> Loaded : Spatial Data Analysis Plugin for Point Pattern (package: SDA4PP)
> Loaded : SelectPlus Menu (package: selectplus)
> Loaded : Table Manager (package: tablemanager)
> Loaded : TopoColour (package: topocolour)
> Loaded : Zoom to Point (package: zoom_to_point)
> rggobi | readInputFile - checking whether R libraries will be loaded or not
> sda4pploadRpackage | readLib - Starting...
> Carico il pacchetto richiesto: rgdal
> Carico il pacchetto richiesto: sp
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.5.4, released 2009/01/07
> Path to GDAL shared files: /usr/share/gdal15
> Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
> Path to PROJ.4 shared files: (autodetected)
> sda4pploadRpackage | loadRgdal - rgdal package loaded.
> Carico il pacchetto richiesto: rggobi
> Carico il pacchetto richiesto: RGtk2
> sda4pploadRpackage | loadRggobi - rggobi package loaded.
> sda4pploadRpackage | readLib - result=""
> rggobi | readInputFile - all R libraries are successfully loaded.
> ReadQGISLayer | getLayerNameWithCombo - sending combobox with added
> layerNames.
> ReadQGISLayer | getLayerNameWithCombo - the error is="Please add some
> vector layers in QGIS."
> The program 'R' received an X Window System error.
> This probably reflects a bug in the program.
> The error was 'BadMatch (invalid parameter attributes)'.
> (Details: serial 38565 error_code 8 request_code 42 minor_code 0)
> (Note to programmers: normally, X errors are reported asynchronously;
> that is, you will receive the error a while after causing it.
> To debug your program, run it with the --sync command line
> option to change this behavior. You can then get a meaningful
> backtrace from your debugger if you break on the gdk_x_error() function.)
> and QGIS crashes.
> Also, please consider giving a more understandable name to your plugin,
> as the acronym is a bit difficult to remember (something like Point
> analysis, or similar).
> All the best, and again many thanks for your work.
> Paolo Cavallini: http://www.faunalia.it/pc
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090611/fcd01c0b/attachment.html
