[Qgis-developer] Plotting Moving Points on a map
Martin Dobias
wonder.sk at gmail.com
Sun Jun 14 06:35:58 EDT 2009
On Thu, Jun 11, 2009 at 12:41 PM, Luca Pascale<pascale.luca.it at gmail.com> wrote:
> After that I want to wait 1 second (for example) and replot the same Feature
> on an update coordinate (x1,y1)= (x,y+something).
> I have tried vl.changeGeometry(.....) but don't works. Any suggestions ?
That's because you would have to put the layer into editing mode. When
in editing mode it gathers all changes to internal buffer and finally
allows to do a commit (store data permanently in data provider) or do
a rollback (forget all changes). You could avoid this by calling
directly provider's changeGeometryValues() function.
For displaying data with regular updates I would suggest you to draw
the points as map canvas items: the main advantage is that the
background map doesn't have to be rendered every second, only the
points are changed.
> Moreover I need that only the Point Vector Layer being refreshed and not
> also the underlying map. Otherway while refresh has done I'll see a white
> screen without any map.
As already written above, map canvas items is the way to go. Try
exploring the QgsVertexMarker class, it might be useful for you.
Martin
