[Qgis-developer] Help with Tutorial and Eclipse
Matthew Denno mgdenno at gmail.com
Sun Jun 21 23:06:11 EDT 2009
Tim,
Thanks for the suggestion, I really appreciate your help.
I added the code below to my *.pro file and it runs now, but with some
errors which I need to look into still.
Added code:
  ADD_DEFINITIONS(-DGUI_EXPORT=)
  ADD_DEFINITIONS(-DCORE_EXPORT=)
  ADD_DEFINITIONS(-DPYTHON_EXPORT=)
I am now getting this message when I try to run it:
  QgsCoordinateReferenceSystem::findMatchingProj will only work if prj acr
ellipsoid acr and proj4string are set!...
  Layer is valid
Some times it runs, sometimes it doesn't after these messages (??).
As a follow-up, do the tutorials need to be compiled against the full source
code or should they work with only the install from the repository?  I have
it "working" with the full source code but am wondering if this is
necessary.
Thanks Again,
Matt
On Sun, Jun 21, 2009 at 12:19 PM, Tim Sutton <lists at linfiniti.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Matthew
> I'm not familiar with eclipse as a C++ IDE but I  wonder if you have
> declared the compiler constants -DCORE_EXPORT , -DGUI_EXPORT and
> - -DPYTHON_EXPORT. It should be fine to declare them as empty vars if you
> are under Linux. This is just a shot in the dark since as I mentioned
> I've never tried to build under eclipse.
> Regards
> Tim
> Matthew Denno wrote:
> > Hello List,
> > I am wondering if someone can help me get the C++ tutorials to compile
> using
> > Eclipse?
> > Here is my set up:
> > - Ubuntu 9.04
> > - QGIS version 1.0.2 standard install from the repositories
> > - QGIS version 1.2.0 compiled and installed to /usr/local
> > - Eclipse Ganymede with CDT and Qt Integration
> > So what I have done is:
> > 1) Create a new Qt GUI Project, GUI Type: QMainWindow (this compiles and
> > runs but doesn't do anything)
> > 2) Add /usr/include/qgis to the project includes
> > 3) Add the following to the .pro file:
> >        INCLUDEPATH += /usr/include/qgis
> >        QT += core gui sql xml svg opengl qt3support
> > 4) Copy and paste the tutorial code from http://blog.qgis.org/node/10 to
> the
> > automatically generated main.cpp file.
> > I have also tried to reference the QGIS version 1.2.0 that was compiled
> > locally, but no luck.
> > When I try to compile the project it looks like the QGIS classes are not
> > recognized and I get the errors below.  It looks like it is finding the
> *.h
> > files.  I suspect that it is a problem with my *.pro file.
> > If someone could help me out it would be greatly appreciated, even just a
> > point in the right direction.
> > ----ERRORS-------------
> > make debug
> > make -f Makefile.Debug
> > make[1]: Entering directory `/home/matt/workspace/QGIS_Test2'
> > /usr/bin/uic-qt4 qgis_test2.ui -o ui_qgis_test2.h
> > g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_SVG_LIB -DQT_QT3SUPPORT_LIB
> > -DQT3_SUPPORT -DQT_SQL_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB
> > -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I.
> > -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui
> > -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml
> > -I/usr/include/qt4/QtSql -I/usr/include/qt4/Qt3Support
> > -I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I/usr/include/qgis
> > -I/usr/X11R6/include -Idebug -I. -o debug/main.o main.cpp
> > In file included from main.cpp:6:
> > /usr/include/qgis/qgsapplication.h:25: error: function definition does
> not
> > declare parameters
> > In file included from main.cpp:7:
> > /usr/include/qgis/qgsproviderregistry.h:39: error: function definition
> does
> > not declare parameters
> > In file included from /usr/include/qgis/qgsrenderer.h:29,
> >                  from /usr/include/qgis/qgssinglesymbolrenderer.h:22,
> >                  from main.cpp:8:
> > /usr/include/qgis/qgis.h:26: error: function definition does not declare
> > parameters
> > In file included from /usr/include/qgis/qgssinglesymbolrenderer.h:22,
> >                  from main.cpp:8:
> > /usr/include/qgis/qgsrenderer.h:39: error: function definition does not
> > declare parameters
> > In file included from main.cpp:8:
> > /usr/include/qgis/qgssinglesymbolrenderer.h:26: error: function
> definition
> > does not declare parameters
> > /usr/include/qgis/qgssinglesymbolrenderer.h:68: error:
> > ‘QgsSingleSymbolRenderer’ has not been declared
> > /usr/include/qgis/qgssinglesymbolrenderer.h:68: error: non-member
> function
> > ‘const QgsSymbol* symbol()’ cannot have cv-qualifier
> > /usr/include/qgis/qgssinglesymbolrenderer.h: In function ‘const
> QgsSymbol*
> > symbol()’:
> > /usr/include/qgis/qgssinglesymbolrenderer.h:70: error: ‘mSymbol’ was not
> > declared in this scope
> > /usr/include/qgis/qgssinglesymbolrenderer.h: At global scope:
> > /usr/include/qgis/qgssinglesymbolrenderer.h:73: error:
> > /usr/include/qgis/qgssinglesymbolrenderer.h:73: error: non-member
> function
> > ‘bool needsAttributes()’ cannot have cv-qualifier
> > In file included from main.cpp:9:
> > /usr/include/qgis/qgsmaplayerregistry.h:35: error: function definition
> does
> > In file included from /usr/include/qgis/qgsrectangle.h:26,
> >                  from /usr/include/qgis/qgsmaplayer.h:27,
> >                  from /usr/include/qgis/qgsvectorlayer.h:28,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgspoint.h:30: error: function definition does not
> declare
> > parameters
> > /usr/include/qgis/qgspoint.h:138: error: expected ‘,’ or ‘...’ before ‘&’
> > token
> > /usr/include/qgis/qgspoint.h:138: error: ISO C++ forbids declaration of
> > ‘QgsPoint’ with no type
> > /usr/include/qgis/qgspoint.h:138: error: ‘bool operator==(int)’ must have
> an
> > argument of class or enumerated type
> > /usr/include/qgis/qgspoint.h:146: error: expected ‘,’ or ‘...’ before ‘&’
> > token
> > /usr/include/qgis/qgspoint.h:146: error: ISO C++ forbids declaration of
> > /usr/include/qgis/qgspoint.h: In function ‘std::ostream&
> > operator<<(std::ostream&, int)’:
> > /usr/include/qgis/qgspoint.h:149: error: ‘p’ was not declared in this
> scope
> > /usr/include/qgis/qgspoint.h: At global scope:
> > /usr/include/qgis/qgspoint.h:146: warning: unused parameter ‘QgsPoint’
> > In file included from /usr/include/qgis/qgsmaplayer.h:27,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgsrectangle.h:35: error: function definition does not
> > declare parameters
> > /usr/include/qgis/qgsrectangle.h:134: error: expected initializer before
> > ‘::’ token
> > /usr/include/qgis/qgsrectangle.h:138: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h: In function ‘void setXMinimum(double)’:
> > /usr/include/qgis/qgsrectangle.h:140: error: ‘xmin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h: At global scope:
> > /usr/include/qgis/qgsrectangle.h:143: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h: In function ‘void setXMaximum(double)’:
> > /usr/include/qgis/qgsrectangle.h:145: error: ‘xmax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:148: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h: In function ‘void setYMinimum(double)’:
> > /usr/include/qgis/qgsrectangle.h:150: error: ‘ymin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:153: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h: In function ‘void setYMaximum(double)’:
> > /usr/include/qgis/qgsrectangle.h:155: error: ‘ymax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:158: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:158: error: non-member function ‘double
> > xMaximum()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double xMaximum()’:
> > /usr/include/qgis/qgsrectangle.h:160: error: ‘xmax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:163: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:163: error: non-member function ‘double
> > xMinimum()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double xMinimum()’:
> > /usr/include/qgis/qgsrectangle.h:165: error: ‘xmin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:168: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:168: error: non-member function ‘double
> > yMaximum()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double yMaximum()’:
> > /usr/include/qgis/qgsrectangle.h:170: error: ‘ymax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:173: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:173: error: non-member function ‘double
> > yMinimum()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double yMinimum()’:
> > /usr/include/qgis/qgsrectangle.h:175: error: ‘ymin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:178: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:178: error: non-member function ‘double
> > width()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double width()’:
> > /usr/include/qgis/qgsrectangle.h:180: error: ‘xmax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:180: error: ‘xmin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:183: error: ‘QgsRectangle’ has not been
> > declared
> > /usr/include/qgis/qgsrectangle.h:183: error: non-member function ‘double
> > height()’ cannot have cv-qualifier
> > /usr/include/qgis/qgsrectangle.h: In function ‘double height()’:
> > /usr/include/qgis/qgsrectangle.h:185: error: ‘ymax’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:185: error: ‘ymin’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsrectangle.h:188: error: ‘QgsPoint’ does not name a
> type
> > /usr/include/qgis/qgsrectangle.h:192: error: expected ‘,’ or ‘...’ before
> > ‘&’ token
> > /usr/include/qgis/qgsrectangle.h:192: error: ISO C++ forbids declaration
> of
> > ‘QgsRectangle’ with no type
> > /usr/include/qgis/qgsrectangle.h: In function ‘std::ostream&
> > /usr/include/qgis/qgsrectangle.h:192: error: redefinition of
> ‘std::ostream&
> > /usr/include/qgis/qgspoint.h:146: error: ‘std::ostream&
> > operator<<(std::ostream&, int)’ previously defined here
> > /usr/include/qgis/qgsrectangle.h:194: error: ‘r’ was not declared in this
> > scope
> > /usr/include/qgis/qgsrectangle.h:192: warning: unused parameter
> > ‘QgsRectangle’
> > In file included from /usr/include/qgis/qgsvectorlayer.h:28,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgsmaplayer.h:41: error: function definition does not
> > declare parameters
> > In file included from /usr/include/qgis/qgsvectorlayer.h:29,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgsfeature.h:49: error: function definition does not
> > declare parameters
> > In file included from /usr/include/qgis/qgsvectorlayer.h:30,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgssnapper.h:32: error: function definition does not
> > declare parameters
> > /usr/include/qgis/qgssnapper.h:58: error: function definition does not
> > declare parameters
> > In file included from /usr/include/qgis/qgsvectorlayer.h:32,
> >                  from main.cpp:10:
> > /usr/include/qgis/qgsfield.h:29: error: function definition does not
> declare
> > parameters
> > /usr/include/qgis/qgsfield.h:147: error: ‘QgsField’ was not declared in
> this
> > scope
> > /usr/include/qgis/qgsfield.h:147: error: template argument 2 is invalid
> > /usr/include/qgis/qgsfield.h:147: error: invalid type in declaration
> before
> > ‘;’ token
> > In file included from main.cpp:10:
> > /usr/include/qgis/qgsvectorlayer.h:57: error: function definition does
> not
> > declare parameters
> > In file included from main.cpp:11:
> > /usr/include/qgis/qgsmapcanvas.h:62: error: function definition does not
> > declare parameters
> > /usr/include/qgis/qgsmapcanvas.h:93: error: function definition does not
> > declare parameters
> > main.cpp: In function ‘int main(int, char**)’:
> > main.cpp:22: error: ‘QgsApplication’ was not declared in this scope
> > main.cpp:22: error: expected `;' before ‘app’
> > main.cpp:30: error: ‘QgsProviderRegistry’ has not been declared
> > main.cpp:33: error: invalid use of incomplete type ‘struct
> QgsVectorLayer’
> > /usr/include/qgis/qgsrenderer.h:22: error: forward declaration of ‘struct
> > QgsVectorLayer’
> > main.cpp:34: error: ‘QgsSingleSymbolRenderer’ was not declared in this
> scope
> > main.cpp:34: error: ‘mypRenderer’ was not declared in this scope
> > main.cpp:34: error: expected type-specifier before
> > main.cpp:34: error: expected `;' before ‘QgsSingleSymbolRenderer’
> > main.cpp:35: error: ‘QgsMapCanvasLayer’ was not declared in this scope
> > main.cpp:35: error: template argument 1 is invalid
> > main.cpp:35: error: invalid type in declaration before ‘;’ token
> > main.cpp:37: error: invalid use of incomplete type ‘struct
> QgsVectorLayer’
> > QgsVectorLayer’
> > main.cpp:38: error: invalid use of incomplete type ‘struct
> QgsVectorLayer’
> > QgsVectorLayer’
> > main.cpp:48: error: ‘QgsMapLayerRegistry’ has not been declared
> > main.cpp:50: error: request for member ‘append’ in ‘myLayerSet’, which is
> of
> > non-class type ‘int’
> > main.cpp:52: error: ‘QgsMapCanvas’ was not declared in this scope
> > main.cpp:52: error: ‘mypMapCanvas’ was not declared in this scope
> > main.cpp:52: error: expected type-specifier before ‘QgsMapCanvas’
> > main.cpp:52: error: expected `;' before ‘QgsMapCanvas’
> > main.cpp:53: error: invalid use of incomplete type ‘struct
> QgsVectorLayer’
> > QgsVectorLayer’
> > main.cpp:63: error: ‘app’ was not declared in this scope
> > main.cpp: At global scope:
> > main.cpp:19: warning: unused parameter ‘argc’
> > main.cpp:19: warning: unused parameter ‘argv’
> > make[1]: *** [debug/main.o] Error 1
> > make: *** [debug] Error 2
> > make[1]: Leaving directory `/home/matt/workspace/QGIS_Test2'
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAko+XXIACgkQqk07qZdiYjdWEQCfQ7T9uOkK86WmYAQ+e0yett6Q
> losAoL45e+VMUvlxVDOAKYW8VhkVOqSm
> =4Ifu
> -----END PGP SIGNATURE-----
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090621/0fee3eba/attachment-0001.html
