[Qgis-developer] custom prj
Paolo Cavallini cavallini at faunalia.it
Tue Mar 3 05:10:24 EST 2009
Hi all.
Apparently newer versions of QGIS have problems reading custom
projection files (see attached).
In one of the IT regions, the administrations use a custom projection
system, with a False_Northing at -4000000 (I know it is stupid).
QGIS 0.9.2 can read it and reproject it, whereas 1.0 fails.
Probably the newer versions check whether the prj corresponds to a EPSG
projection, and in case it is not it refuses considering it, but IMHO it
should just warn the user ("non standard projection") and proceed.
Am I missing something?
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090303/5e0f2e26/province-0001.bin
