[Qgis-developer] custom prj
Martin Dobias
wonder.sk at gmail.com
Fri Mar 6 08:19:50 EST 2009
On Wed, Mar 4, 2009 at 3:16 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Martin Dobias ha scritto:
>> I agree that this is not user-friendly. A solution might be to tell
>> the user that we have an unknown reference system and ask him whether
>> he would like to add it (otherwise it won't work).
> Hi Martin.
> Agreed, this would be a good solution. However, apparently earlier
> versions (0.9.2 at least) could use the custom prj, which although not
> completely sane it's far easier for users.
> Would the modification be easy to do?
Well, 0.9.2 is quite some time back and a lot of code has been changed
since then, so I'm not sure about this.
But you say that 0.9.2 is able to work with the projection although
it's not included in the custom projections?
Martin
