[Qgis-developer] controlling visibility
Carson Farmer
carson.farmer at gmail.com
Tue Mar 10 11:40:08 EDT 2009
Hello devs,
I am very close to having a QgsTableProvider for loading, accessing,
editing, and visualising non-spatial tables in QGIS. It is really quite
simple, and essentially is an ogr provider for non-spatial data (i.e.
can read dbf, csv, and probably postgres eventually as well). Currently,
I can create a QgsVectorLayer with the 'table' provider, which is
essentially just a normal QgsVectorLayer that has no spatial information
(i.e. extent, geometries). You can do most things, including access the
provider, and 'select', 'nextFeature', 'featureAtId', etc from there.
The only problems that I have noticed so far are:
a) If Options > Rendering > 'By default new layers added to the map
should be displayed' is checked, QGIS crashes when the table is loaded.
b) When added to the layer list, a polygon icon is displayed (I would
like to change this to a attribute table icon).
c) Currently, when right clicking the table layer, all context menu
items are visible (I would like to remove some of these options: remove
everything except open attribute table, remove, toggle editing, and rename).
To address a), I would like to figure out how to automatically set the
visibility of these 'table' layers to False, and keep it this way. I
haven't really looked too much into b) and c), but if someone has a
quick suggestion that would greatly help me out.
The reasons for attempting to implement a QgsTableProvider are several:
1) It allows people to view non-spatial tables, edit them, and all sorts
of useful things all from one place, and more importantly: 2) It will
make joining and relating tables possible/much easier: OGR has the
ability to join tables using SQL like queries, by I think this would
make it possible to create non-permanent table joins in QGIS (an often
requested feature).
My eventual goal would be to allow table joins, appending the additional
tables to the Files list of a layer...
Anyway, any input/help is greatly appreciated, especially regarding the
above items ;-)
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
