[Qgis-developer] PostGisTools Plugin
Mauricio de Paulo
mauricio.dev at gmail.com
Wed Mar 11 19:39:00 EDT 2009
The first thing I noticed from reading some of your code is that you
still use pygresql. Mind to change it to QtSql? As we've talked before,
it already comes inside the regular qt windows pack. I didn't try
postgis manager on windows but on 1.0.0 preview it came with qtsql. Good
idea? Bad?
Hum... I didn't get any reply from testing the plugin so I decided to
upload it as a separate plugin for a while. For testing purposes as I
need feedback of it's usability and interest of the community in that I
keep on the work. Or else I can stop. :P Lie.
I still didn't take the time to write the Tools Editor, but I think you
can get the idea from the pic I sent last time.
See ya.
Maurício de Paulo
On Wed, 2009-03-11 at 18:03 +0100, Martin Dobias wrote:
> On Sat, Mar 7, 2009 at 3:55 AM, Mauricio de Paulo
> <mauricio.dev at gmail.com> wrote:
> > Hi Martin.
> > I'm glad to hear it. It's actually pretty easy to insert it inside
> > Postgis Manager as the only difference would be eliminating the
> > __init__.py.
> > Whenever you feel like it, I can add the code to the Manager. Have you
> > tested the plugin itself yet?
> > I think that even though the interface should be inside postgis
> > manager, the access to the favourites should be from the plugin toolbox.
> > What do you think?
> Mauricio,
> I haven't tried to run it, I just took a look at the code ;-)
> Sorry for the lag, I'm on vacations this week. I'll evaluate options
> of the integration once I'll be back
> Bye
> Martin
