[Qgis-developer] Data for QGIS Hackfest
Andreas Neumann
a.neumann at carto.net
Sun Mar 22 08:00:03 EDT 2009
Hi Bob,
The QGIS is now over, as far as I know, but your data might still be
useful for performance testing of QGIS trunk.
I'd like the mention that the display of very large rasters is normally
not a problem if you used gdaladdo to add pyramids to your data. You can
use rasters with the hundreds of gigs of filesize without a bottleneck.
You'd have to build the pyramids however. If you store your data in
multiple files instead of just one, you should build a tileindex with
gdaltindex. See http://www.gdal.org/gdal_utilities.html for more infos.
You should definitively give the display of rasters in qgis a try - they
should perform well.
The display of big vector data is another issues. Did you build spatial
indices? Are you directly loading from the shapefiles or from postgis?
In realworld scenarios you should use various scale levels and reduce
your vector data with SQL WHERE clauses (e.g. only display major rivers
in a river network). If you display tenthousands/hundredthousands of
vector features in one display, you probably have generalization and map
reading problem anyway. There is no value in displaying all of your
vector features, say on a state level when you totally clutter your map
display and can't distinguish individual features anymore.
This doesn't mean that performance shouldn't be improved in QGIS. I just
mean that there are ways for you to improve performance with the
existing QGIS by improving the data structure of your existing data.
Andreas
Bob Bruce wrote:
> I am pleased to see that you're having the hackfest to improve QGIS.
> If want some data to test with QGIS, I have lots. I have a 2500 km
> sq area of northern Manitoba having topographical mapping with 7
> layers and 30 shape files of 234 Mb. This mapping was done with
> orthophotography of .5m pixels and is quite detailed. You are welcome
> to use that dataset for testing QGIS,
> I have found significant performance issues in QGIS with this data the
> draws take at least 30 seconds for an area of 50 km X 34 km for the
> water layer. I could FTP it to you. I haven't even tried loading the
> ortho photos which are .5m resolution and are 5 km X 5 km with a file
> size of 293Mb.
> I can FTP this dataset to a site of your choosing if you want to use it.
> Bob Bruce
> Qgis-developer mailing list
