[Qgis-developer] Improvements to open vector dialog
godofredo contreras
frdcn at hotmail.com
Mon Mar 23 14:41:25 EDT 2009
Hi Paolo:
The ogr driver for sqlite is outdated and does not work with Spatialite.
It uses diferent table structure that spatialite (for example in sqlite driver
the table spatial_ref_sys uses a column named SRTEXT while spatialite has
a column named proj4text). I have been working in an ogr driver for spatialite
based in sqlite driver, solving the problems with tables structures and solving
the problems with constrains but it needs more work and more testing.
Regards
Godofredo Contreras
> Date: Mon, 23 Mar 2009 08:18:09 +0100
> From: cavallini at faunalia.it
> To: frdcn at hotmail.com
> CC: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Improvements to open vector dialog
> godofredo contreras ha scritto:
> > Thank you for the feedback, I will test it and try to fix the problem if it
> > is ogr provider specific or post a bug in gdal/ogr trac.
> Hi Godofredo.
> I tried pushing the provider a bit further, asking it to open a
> SpatiaLite file, but it fails to recognize spatial data (including
> projections, and crashes when trying to open the attached table.
> Nothing serious I guess, I know SpatiaLite support is still
> experimental, but it might be interesting to know.
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
_________________________________________________________________
Get quick access to your favorite MSN content with Internet Explorer 8.
http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037MSN55C0701A
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090323/82a6881a/attachment.html
