[Qgis-developer] Problem compiling with SpatiaLite support
Andreas Neumann
a.neumann at carto.net
Thu Mar 26 13:29:35 EDT 2009
With 2.3 it compiles fine - thanks!
I still haven't tested it but with geodata, but will do tomorrow.
Are there any tools available to transfer Postgis to SpatiaLite tables? My
idea is to use Postgis as the main repository, but use SpatiaLite to
checkout data (e.g. for laptops).
It would be cool if QGIS would provide a tool to copy Postgis tables to
SpatiaLite and vice versa without having to go through a shapefile (with
its limitations, e.g. in column-name lengths)
Thanks a lot,
Andreas
On Thu, March 26, 2009 12:58 pm, Alessandro Furieri wrote:
> Andreas Neumann ha scritto:
>> Hi,
>> I was trying to compile with SpatiaLite support enabled, however, I am
>> running into an error:
> Hi Andreas,
> your problem is exactly the same noticed
> by William Kyngesburye [using v.2.2 headers]
> very quick fix: in 'qgsspatialiteprovider.h' add:
> #include <stdio.h>
> immediately before:
> #include <spatialite/gaiageo.h>
> even better: use the latest SpatiaLite v.2.3
> http://www.gaia-gis.it/spatialite-2.3/
> bye,
> Sandro
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
