[osgeo4w-dev] Re: [Qgis-developer] cannot build qgis with python inside osgeo4w: python isn't detected
G. Allegri giohappy at gmail.com
Mon Mar 30 08:09:59 EDT 2009
> Please don't.  CMake follows convensions.  It knows that libraries are
> called name.lib for MSVC and libname.a for Unix (and MinGW).   If you
> change FindGRASS you break it for other platforms.
Ok, I will.
> My incarnation of that script is on http://buten.norbit.de/~jef/mklibs.
> That also takes care of the lib renaming and removes the version tag
> from the libraries.
It seems to do the same as mine.
I've made it work... it was an error of extra characters inserted by
notepad. I had to remove them with an hex editor!
