[Qgis-developer] OSX build instructions update
William Kyngesburye
woklist at kyngchaos.com
Sat May 2 10:33:18 EDT 2009
On May 2, 2009, at 9:05 AM, Tim Sutton wrote:
> Hi William
> On 02 May 2009, at 6:00 AM, William Kyngesburye wrote:
>> I took the liberty of updating the INSTALL build instructions for
>> OSX in trunk. INSTALL should probably be updated for other
>> systems, as there are some old version references (both
>> dependencies, and QGIS itself). Should INSTALL be updated in
>> release 1.1 before release?
> I think its missed the cut for 1.1 - we'll include an update for
> 1.1.1. Note that INSTALL is actually an autogenerated document from
> docs/INSTALL.t2t (we use text2tags to maintain it). so we will need
> to port your changes into the source t2t document. The same source
> document is used to generate wiki markup for the wiki install page
> and LaTeX for the user guide.
I knew the wiki page was generated from something in the source. And
I now vaguely remember the t2t doc ;)
> It would probably be good to include both 'old' cmake way and the
> new xcode gui way of building on Mac OS X although I guess this
> involves some duplication of effort....
I did leave the cmake build info in there.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
