[Qgis-developer] Slow project opening
Craig Leat
craig.leat at gmail.com
Tue May 5 10:55:25 EDT 2009
Hi
I have a project with a few hundred raster files and opening of the
QGIS project file is very slow (> 20 minutes). I have had a few
crashes recently and so waiting 20 minutes to open the project again
is not much fun. The following messages pop up for each raster layer
and I wish to know if these failures might be contributing
significantly to my slow project opening. If these failures are
significant can you suggest how to deal with them?
Many thanks
Craig
Warning: QgsCoordinateReferenceSystem::getRecord failed : select *
from tbl_srs where parameters='+proj=tmerc +lat_0=0 +lon_0=31 +k=1
+x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs'
Warning: QgsCoordinateReferenceSystem::findMatchingProj will only work
if prj acr ellipsoid acr and proj4string are set!...
Critical: QgsCoordinateReferenceSystem::createFromWkt -- theWkt is
uninitialised, operation failed
BTW I'm running trunk r10261
