[Qgis-developer] How to use x-code qgis installer
William Kyngesburye woklist at kyngchaos.com
Tue May 5 12:34:37 EDT 2009
Note that Xcode defaults to the first configuration alphabetically,
which makes the Debug build default.  Use '-configuration Release' for
a normal build.
I haven't tried it myself, but it sounds like you have and it's
working.  Good to know.
On May 5, 2009, at 10:59 AM, John C. Tull wrote:
> If you are comfortable with the Terminal, you have Apple's developer
> tools installed, and you have all of William's frameworks that are
> necessary for qgis installation, you can download the qgis source
> with svn, cd to the qgis_source/mac/xcode directory, then issue the
> command 'xcodebuild'. This will build the application if nothing
> fails along the way without having to fool with Xcode itself. You
> may need to change the python setting in qgis_user.xcconfig (copy
> the template) to 'PYTHON_FORM = system' if you use the native Apple-
> supplied python and python bindings are not building.
> Once you get a build, you can then copy the application from the
> build/native/Release directory to your Applications folder. I build
> the trunk source to play with new features and help report bugs, so
> I delete the build directory every time I want to make a new build.
> John
> On May 5, 2009, at 6:34 AM, William Kyngesburye wrote:
>> Hm, I'll have to think about that.  It shouldn't be too hard with
>> what's in the readme, but some people may need more details.
>> Basically, you should be able to build Qgis by editing the
>> qgis_user.xcconfig, opening the project in Xcode and selecting/
>> clicking Build.
>> Note that the project download on my site is for Qgis 1.0.1, though
>> it should be usable for 1.0.2, the internal build needs updating.
>> The trunk project is way out of date, and I just now removed it.
>> It's up to date in the trunk source.
>> On May 5, 2009, at 6:04 AM, Luca Mandolesi wrote:
>>> Hi, I use mac os x and I'm interested to understand how to build
>>> qgis from xCode project of http://www.kyngchaos.com. The only
>>> documentation it's the readme.txt inside the xCode folder or I
>>> must to read somes others tutorial, for example how to use xCode,
>>> etc.?
>>> Thanks a lot
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> [Trillian]  What are you supposed to do WITH a maniacally depressed
>> robot?
>> [Marvin]  You think you have problems?  What are you supposed to do
>> if you ARE a maniacally depressed robot?  No, don't try and answer,
>> I'm 50,000 times more intelligent than you and even I don't know
>> the answer...
>> - HitchHiker's Guide to the Galaxy
"Mon Dieu! but they are all alike.  Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings.  And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
