AW: [Qgis-developer] Problem with WMS/WFS connections
Hugentobler Marco
marco.hugentobler at karto.baug.ethz.ch
Fri May 15 05:38:39 EDT 2009
Hi Michele
This problem happens on some computers, but I don't know the reason.
I had a training two months ago with five participants, all with ubuntu 8.10, qgis packages installed and identical configuration. The problem you described happened on three of them, but not on the other two (and also not on my laptop). I did a bit of research with the debugger and compiled Qt from source. My impression was that the problem even comes from a level below Qt.
Does someone know more about it or can do some research about it? As it does not happen on one of my computers, I cannot make further examinations.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Michele Beneventi
Gesendet: Fr 15.05.2009 10:11
An: giovanni.manghi at faunalia.pt
Cc: qgis-developer
Betreff: Re: [Qgis-developer] Problem with WMS/WFS connections
Uhmm... I begin to think that the problem is not qgis.
Thanks
Michele
On Fri, May 15, 2009 at 10:06 AM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
>> Warning: url is: http://webgis.regione.sardegna.it/geoserver/wfs?
>> Segmentation fault
> Hi,
> I gave a try to the above wfs service, and I cannot replicate your
> problem.
> The only error I have when I try to add a layer is "the layer in not a
> valid layer and cannot be added to the map".
> qgis 1.1.0 on ubuntu 8.10
> -- Giovanni --
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
