[Qgis-developer] fTOOLS Delaunay triangulation
kimaidou
kimaidou at gmail.com
Fri May 22 08:50:45 EDT 2009
Waou, this is great ! I love the reactivity and resources of this
mailing list ! One question and bim ! A gpl solution to provide the
desired functionnality !
Kimaidou
2009/5/22, Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> And here's a GPL'd command line tool that computes
> alpha shapes from lat/long points and outputs a polygon
> Shapefile:
> http://code.flickr.com/blog/2008/10/30/the-shape-of-alpha/
> http://code.flickr.com/svn/trunk/clustr/
> Ben
> Benjamin Ducke wrote:
>> All you need seems to be here:
>> http://www.cgal.org/
>> In particular:
>> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#Part:TriangulationsAndDelaunayTriangulations
>> Most of the code is licensed under the QPL:
>> http://doc.trolltech.com/4.3/qpl.html
>> a quick glance does not reveal any immediate problems with that for QGIS
>> development.
>> It would be really great to see some of CGAL's computational geometry
>> tools in a QGIS plug-in!
>> Ben
>> bmoskovi at surewest.net wrote:
>>> Hello Carson,
>>> It would be great if Alpha Shapes (a kind of concave hull) can be
>>> added to fTools. Somewhere I have a paper that describe the algorithm
>>> fully. So, I did a quick search and found this:
>>> http://www.cs.wustl.edu/~pless/546/lectures/lecture22.pdf
>>> Bob (aka cgs_bob)
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Benjamin Ducke
> Senior Geospatial Consultant
> Oxford Archaeology
> Janus House
> Osney Mead
> OX2 0ES
> Oxford, U.K.
> Tel: +44 (0)1865 263 800 (switchboard)
> Tel: +44 (0)1865 980 758 (direct)
> Fax :+44 (0)1865 793 496
> Files attached to this email may be in ISO 26300 format (OASIS Open Document
> Format). If you have difficulty opening them, please visit
> http://iso26300.info for more information.
