[Qgis-developer] WFS to shp
Giovanni Manghi
giovanni.manghi at gmail.com
Fri May 29 04:44:23 EDT 2009
it happens also if the source is a postgis layer, I know because I
noticed the same behavior while setting up a wfs server with sources
of different types. But it happens also with other desktop clients but
not always (sometimes they show correctly all the features where qgis
don't)... so I'm not sure is a qgis problem.
If someone want investigate further I can provide a wfs sever address
and source data in shp format.
-- Giovanni --
On Fri, May 29, 2009 at 12:33 AM, Milena Nowotarska
<do.milenki at gmail.com> wrote:
> Hello Developers,
> playing with QGIS I saved a WFS layer to shapefile and noticed that
> not all the features are present on the new shp layer.
> I was using http://webservices.ionicsoft.com/unData/wfs/UN , layer
> COUNTRY, saved it to country1.shp, as shown on attached printscreen.
> I have no idea if that is WFS itself or the plugin problem, but
> thought you might be interested :)
> Made 3 tries, also loaded WMS layer again and the result was the same,
> lit. the same features were missing.
> Milena
> Qgis-developer mailing list
