[Qgis-developer] Which compiler should I use to build example code?
Henri De Feraudy feraudyh at yahoo.com
Sun Nov 1 09:36:50 EST 2009
Hello,
  I have installed cmake, read some documentation, checked out the latest timtut1 project and
run cmake, then the Microsoft VS 2008 C++ compiler.
(This is like using a sledge hammer to crack a peanut ;))
With eboth Qgis installers I get an error at link time: the linker complains as follows
C:\Program Files\Quantum GIS\bin\qgis_core.dll : fatal error LNK1107: invalid or corrupt file: cannot read at 0x2F0
(About the same mistake occurs when I use the osgeo release.)
By the way the non-osgeo release does not have the includes for GEOS and GDAL
and the names of the libraries for geos and gdal are not the ones that Cmake is looking for.
Maybe I should be using a "development library"??
Maybe I should download a more recent (than 1.0.2 Kore) installer?
Yours truly
Henri
On Sat, Oct 31, 2009 at 10:46 PM, Henri De Feraudy <feraudyh at yahoo.com> wrote:
> Thankyou Tim,
> The first example to start with (tutorial 1) . I'd love to be able to continue and make it better, with rectangular selections (I guess that's the rubber band selection example).
OK. You need to build it using CMake. Standard procedure should be
(guessing a little because I'm a linux user):
Install osgeo4w into the standard location (c:\osgeo4w) including all
developer libs
Use your system properties to export the LIB_DIR environment var to
point to c:\osgeo4w
enter the tut dir
mkdir build
cd build
cmakesetup ..
configure (c)
generate (g)
nmake
Windows gurus please chip in where I have gone wrong above...
> As for the term div lib, I dont know what you mean. I am handicapped by the fact that I have been out of C & C++ programming for over a decade until a week ago :(.
Sorry that was a typo, I meant dev (ie developer) libs.
I just made some small tweaks to tuts 1-4 so please update from svn
when you get the chance.
Regards
Tim
> As Manuel says in Fawlty Towers "But I'm learning...".
> Henri
> --- On Sat, 10/31/09, Tim Sutton <lists at linfiniti.com> wrote:
> From: Tim Sutton <lists at linfiniti.com>
> Subject: Re: [Qgis-developer] Which compiler should I use to build example code?
> To: "Henri De Feraudy" <feraudyh at yahoo.com>, qgis-developer-bounces at lists.osgeo.org, "QGIS Developer" <qgis-developer at lists.osgeo.org>
> Date: Saturday, October 31, 2009, 9:18 PM
> Hi
> Which specific example are you trying to build? You should be able to build with msvc assuming you have LIB_DIR set to an osgeo4w installation the includes all the needed div libs.
> Regards
> Tim
> Sent from my mobile phone.
> -----Original Message-----
> From: Henri De Feraudy <feraudyh at yahoo.com>
> Date: Sat, 31 Oct 2009 12:58:36
> To: <qgis-developer at lists.osgeo.org>
> Subject: [Qgis-developer] Which compiler should I use to build example code?
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091101/54a9dbab/attachment-0001.html
