[Qgis-developer] Installing the Qgis 1.0.2 package for Ubuntu
Joseph Reeves iknowjoseph at gmail.com
Tue Nov 3 07:02:03 EST 2009
9.10 is there as the default; you'll see it reads:
"You can update your system with unsupported packages from this
untrusted PPA by adding ppa:qgis/stable to your system's Software
Sources. "
The it says:
"Not using Ubuntu 9.10 (karmic)?"
So click there if you're not using Karmic, otherwise, read the first sentence.
That's how I understand it at least...
Cheers, Joseph
2009/11/3 Henri De Feraudy <feraudyh at yahoo.com>:
> Hello,
>  Since I cant get the first tutorial application (timtut1.exe) to work for
> Windows I'm trying to see if I can make it work on Ubuntu.
> So I installed Ubuntu Karmic Koala last night. It's been out since the 29th of October, if I remember rightly.
> When I go to look for the Ubuntu package on
> https://launchpad.net/~qgis/+archive/stable
> I see that Karmic Koala (the latest Ubuntu) is not yet taken into account.
> Can I use the Jaunty package?
> Henri
> Qgis-developer mailing list
