[Qgis-developer] Composer grid issue
John C. Tull john.tull at wildnevada.org
Wed Nov 4 20:25:52 EST 2009
William,
You can disregard. I reverted to qt-4.5.3-carbon and the issue does
appear to be tied to qt-4.6. I have not tried 4.6-carbon to see if it
is a cocoa-specific issue yet.
John
On Nov 4, 2009, at 12:15 PM, John C. Tull wrote:
> William,
> I was wondering if you have seen the problem with the new composer
> breaking some core OS X functionality? If I open an existing project
> (possibly true with new projects as well), the dock is killed,
> command-tab to switch between applications does not function, expose
> and spaces are non-functional, and I have to logout to cure my ails.
> Have you built and tested the new composer at all? I'm trying to see
> if this might be narrowed down to my use of the qt-4.6-cocoa beta or
> if it is something internal to the new composer changes irrespective
> of the qt version.
> If you could test the current trunk, that would be useful. I just
> built the xcode project, and the same problem exists as with the
> cmake build.
> Thanks,
> John
> Begin forwarded message:
>> From: "John C. Tull" <jctull at gmail.com>
>> Date: October 30, 2009 10:42:30 AM PDT
>> To: Marco Hugentobler <marco at hugis.net>
>> Cc: qgis-developer at lists.osgeo.org
>> Subject: Re: [Qgis-developer] Composer grid issue
>> Marco,
>> On Oct 30, 2009, at 3:22 AM, Marco Hugentobler wrote:
>>>> For some reason, my old project now crashes if I try to open in
>>>> qgis.
>>>> I suspect this might be from changes in the composer structure
>>>> for qgs
>>>> files, but not certain.
>>> Oh, this should not happen. Project reading should be backwards
>>> compatible.
>>> Unfortunately, it does not crash with my test projects. Could you
>>> send me the
>>> project file for testing?
>> The crashing issue may be specific to that project, perhaps a
>> symbology issue. I was able to open several other project files
>> without crashing, but a new and more serious issue has arisen. Now,
>> opening the a project brings a map composer window to the screen as
>> well as the canvas. This composer window cannot be minimized or
>> closed. Worse, it causes Mac OS X Finder, Dock, and Spaces to all
>> cease functioning. Essentially, it paralyzes the OS X gui. Quitting
>> qgis does not fix this. The only solution I have found is to logout
>> and log back in to restore gui functionality.
>> I should add that I am using qt-4.6-beta, so it would be great if
>> another Mac user with a more conservative qt environment could test
>> this and see if it happens for them. The key is having an existing
>> qgis project.
>> Beyond that, I do not have much information to provide that may
>> help uncover this. We can try to work on this off-list if you would
>> like.
>> Regards,
>> John
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091104/b51af3e9/attachment.html
