[Qgis-developer] Updating Win Build - stuck
Alex Mandel
tech_dev at wildintellect.com
Tue Nov 10 03:37:20 EST 2009
Steve,
I'd be very interested in seeing any other notes you have on the
process. If you are building via MinGW and are willing to share in the
process I will be happy to help get your builds into the NSIS script to
create a new version of the Standalone installer.
My only goal here is a standalone installer with grass and python like
Macro used to make. It would be great if this didn't rely on a single
person as in the past so I would be very happy to collaborate with you.
FYI, I have access to virtual machines of most versions of windows for
building and testing but do not use windows myself(anymore).
Thanks,
Alex
S Mizuno wrote:
> Alex,
> I believe the problem is that qgssvnversion.h is not being constructed properly due to a test for MSVC in CMakeLists.txt in the top level source directory that should also test for MINGW , like in Python.cmake as you found. *nix commands are attempted, but fail since it is a Windows system.
> see attached patch file
> I hope this helps.
> I have been using MinGW building for some time now and have some things I do to make compiling a little easier on my build system, which is somewhat different from the way Marco Pasetti documented Windows building. I would be willing to share these if you are interested. Most of these allow CMake to find libraries and headers without having to manually set the variables.
> Steve
> ---------- Original Message ----------
> From: Alex Mandel <tech_dev at wildintellect.com>
> To: qgis-developer <qgis-developer at lists.osgeo.org>
> Subject: [Qgis-developer] Updating Win Build - stuck
> Date: Sun, 08 Nov 2009 00:05:10 -0800
> All,
> I've been working on bringing the mingw/msys build back up to date with
> a working GRASS. So far via Marco's instructions and some shortcutting
> via OSGeo4w I think I'm getting close.
> Ran into an error somewhere between 3-7%, see
> http://img8.imageshack.us/img8/232/cmakeerror.png
> Based on ADKPete's suggestion I tried an mingw build of GEOS instead of
> osgeo4w but that didn't seem to change anything.
> Oh and an FYI, Python.cmake should be changed to check for MINGW or MSVC
> for when to decide to use pyuic4.bat and pyrcc4.bat, or alternately just
> use WIN32. I manually hacked it with that for now, not 100% what the
> final solution is to ensure both build types with find the right python
> files in the cmakesetup.
> Thanks,
> Alex
