[Qgis-developer] Georeferencer improvements
Mailing Lists
lists at linfiniti.com
Tue Nov 10 12:16:32 EST 2009
Hi Maxim
Bear in mind that we are planning in the not so distant future to move
map composer from being a separate window to being a tab so copying
its implementation approach may not end up with a solution that is
consistent over the long term. What about considering making a split
map view in the main window rather, along with a dock panel to hold
the options. On the left canvas have the image you are georeferencing,
and the right the reference image? I can probably make a little mockup
if my explanation is not clear....
Regards
Tim
2009/11/10 Maxim Dubinin <sim at gis-lab.info>:
> I knew you gonna ask ;) Moving GCPs to table is a step forward to it and we have it
> on the aditional list, but not among do-to-release list that I've sent. I guess we can utilize
> GDAL transformation matrix to do error calculations.
> Maxim
> Вы писали 10 ноября 2009 г., 10:53:19:
>>> we're going to work on Georeferencer these days, here is the list of
>>> things we're going to add. If there is something you want to add or
>>> discuss, you are welcome. I cannot promise proposed functionality will be
>>> added, as we operate under tight resourses, but at least it will make it
>>> in todo list.
> BJ> What about displaying errors? It seems essential for me to consider this tool
> BJ> as usable :)
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
