[Qgis-developer] advanced editing tool "Reshape Features"
Marco Hugentobler
marco at hugis.net
Wed Nov 11 03:19:04 EST 2009
Hi all
> There may be some corner cases where the tool fails - Marco may be able
> to explain
I'm sure there are, but currently, there are no open bugs on it ;-)
One thing to consider is that the reshape tool alters the starting position of
a polygon ring or a closed line. So the point that is represented 'twice' will
not be the same any more. I don't expect this to be a problem for most
application but it is something to consider.
Also, the reshapeline is not allowed to cross several polygon rings as this
would generate an invalide polygon.
Regards,
Marco
Am Dienstag, 10. November 2009 22.07:07 schrieb Andreas Neumann:
> Hi Otto,
> I am not the developer but the one who proposed the tool.
> Obviously the tool works on Polygon and Line Features, not on point
> features.
> It replaces the line or polygon part from the first to the last
> intersection with the original line. Obviously, with Polygons this can
> sometime lead to unintended results. It is mainly useful to replace
> smaller parts of a polygon, not major overhauls. For line features it
> works very well.
> to explain.
> Andreas
> Otto Dassau wrote:
> > Hi,
> > I want to write something about the advanced editing tool "Reshape
> > Features". Can the developer explain in a few words, what is important
> > to mention in the manual?
> > thanks a lot
> > Otto
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
