[Qgis-developer] lost QGIS_SVN_VERSION information when using
Debian pbuilder
Ivan Mincik
ivan.mincik at gmail.com
Sat Nov 14 03:14:21 EST 2009
On Fri, Nov 13, 2009 at 5:51 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Ivan,
> On Fri, 13. Nov 2009 at 16:55:32 +0100, Ivan Mincik wrote:
>> I am not very familiar with cmake. Where can I look for ?
> http://trac.osgeo.org/qgis/browser/trunk/qgis/CMakeLists.txt#L342
> When cmake sees a .svn in the source directory it tries to
> determine the checked out revision of the sources.
> The easy solution proabably is to add svnversion to your pbuilder environment.
> Another option is to introduce subversion as build dependency, although
> released versions won't need it.
Thanks a lot.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
