[Qgis-developer] labels and qgis-dev
Andreas Neumann
a.neumann at carto.net
Sat Nov 14 05:49:14 EST 2009
hm - I ran into the same problem. Why did the GUI element for chosing
the label field disappear? Isn't it essential being able to choose the
label attribute field? Or is it the idea that it is taken from the field
chosen for the map tips? If this is the idea, I would object, because
often the map tips should display different content than the labels - at
least for my projects.
Thank you for a clarification from the GUI-team.
Best greetings,
Andreas
Giovanni Manghi wrote:
> Hi all,
> I know that there is a big change in the label framework in the very
> near future, but what about the actual framework? I compiled un linux
> today and installed on windows qgis-dev with osgeo4w, and I noticed that
> there was a GUI change in the "labels" tab, but I cannot see anywhere
> the option "field containing label", so everything you can see is just
> "label".
> thanks in advance
> -- Giovanni --
> Qgis-developer mailing list
