[Qgis-developer] SVG handling in qgis
John C. Tull john.tull at wildnevada.org
Fri Nov 20 17:27:16 EST 2009
Hi Andreas,
Tim said you were the resident svg guru. I have been running into problems with svg images I have created in Inkscape coming through garbled when rendered in qgis. Tim mentioned a minisvg spec, but I cannot find anything on that from a google search.
Is there a means to output svg files from Inkscape or some other for of conversion to make svg files meet the requirements of qgis?
Thanks,
John
