[Qgis-developer] Re: vector affine transformation
Agustin Lobo
alobolistas at gmail.com
Fri Nov 27 08:42:46 EST 2009
Forgot to mention that a panel in which the parameters
could be entered both as you have them and ordered as the
affine transformation matrix would be appreciated by
most users. I think this is how ArcView has it (I do not
use it myself). I find this document useful:
www.quantdec.com/GIS/affine.htm
Agus
Agustin Lobo wrote:
> The problem with "Capture From Map Canvas" is
> that you need 2 canvas, unless both the original and the reference
> objects are
> be very close. The Georeferencer plugin opens the raster to be
> processed in a special window, but that window does not
> let you display a vector. Perhaps that would be enough, a window
> such as the one in Georeferencer but for vectors.
> By now, I'm going to try using Coordinate capture twice, once for the
> vector to be warped and the other for the reference object. Then
> input both sets of coordinates into R and calculate
> the affine transformation matrix there. Then I can either
> go on with the actual transformation in R (package spatstat)
> and then export to QGIS (this is comfortably done thanks to
> manageR) or use your plugin.
> Agus
> Maurício de Paulo wrote:
>> Hum... you mean like georreferencing the vectors?
>> While reading your mail I thought about a "Capture From Map Canvas"
>> for the two translation coordinates.
>> Well, I don't know how the georreferencer is written, but I can try to
>> think about reusing it's code. I'm going to take a look at it.
>> Thanks for the tip.
>> Best regards,
>> Mauricio de Paulo
>> On Fri, Nov 27, 2009 at 9:36 AM, Agustin Lobo <aloboaleu at gmail.com
>> <mailto:aloboaleu at gmail.com>> wrote:
>> Hi!
>> It's often the case in which you actually don't know
>> the values for the affine transformation for
>> plugin qgsAffine but just some pairs of corresponding coordinates.
>> I understand that including a facility such as the one for raster
>> georeference would be very useful but quite a work, thus I wonder
>> if the raster georeference plugin could actually output this
>> information which could then be fed to qgsAffine?
>> Agus
>> -- Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> LLuis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> email: Agustin.Lobo at ija.csic.es <mailto:Agustin.Lobo at ija.csic.es>
>> http://www.ija.csic.es/gt/obster
