[Qgis-developer] Layer visibility shown in layers table
strk strk at keybit.net
Fri Oct 2 09:29:15 EDT 2009
Hi qgis heroes,
I'm playing with min/max scale visibility range for layers in an
attempt to have some sort of automatic resolution switching.
Basically I have multiple layers for multiple resolutions and tweak
the scale range in some way.
Question1: am I doing it WRONG ? :) [ maybe there's a layers group for a start ? ]
Question2: does trunk give a visual sign for a layer being visible or not
           based on scale range ? [ I'm using 1.3.0 ]
I think it'd be very useful to have the second behaviour in general, so you
can easily see if a layer is being rendered or not (since the visibility
checkbox is always active no matter scale-based visibility...)
TIA
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
