[Qgis-developer] Re: [Qgis-user] Value Tool Plug-in Problem
William Kyngesburye woklist at kyngchaos.com
Fri Oct 2 19:34:18 EDT 2009
Ah, raster.  OK, no complaints about Qwt5.  Move the cursor around the
map and the little red dot bounces up-n-down the graph.
Tested on full version on Tiger and Snow (I can try Leo, and
standalones, later).
On Oct 2, 2009, at 5:44 PM, John C. Tull wrote:
> Help? Not sure. Depends on whether there is a website or not, etc.
> Some are documented in the help documentation.
> If you load a raster (any raster), enable the plugin (there should
> be a panel, as you mentioned), then tick the second box (Value/
> Graph), an interactive graph should show up. If qwt is not being
> picked up, then it will say qwt not found, or similar.
> Agus: are your students using the most current binary?
> Regards,
> John
> On Oct 2, 2009, at 12:46 PM, William Kyngesburye wrote:
>> When is it failing?  I installed it in my current Qgis 1.3 and
>> enabled it, no problems so far.  I see the panel, but I have no
>> clue on how it works (do plugins have help?).
>> On Oct 2, 2009, at 2:23 PM, John C. Tull wrote:
>>> Thanks for that clarification, William. I was unaware of that.
>>> My build instructions were based on using your frameworks and my
>>> own trunk build of qgis. Do you have any suggestions on getting
>>> the plug-in working with your binary? Apparently something is not
>>> being picked up if the plugin is reporting qwt as missing for
>>> people.
>>> John
>>> On Oct 2, 2009, at 11:45 AM, William Kyngesburye wrote:
>>>> On Oct 2, 2009, at 12:46 PM, John C.Tull wrote:
>>>>> The gdal and osgeo modules are part of William's gdal framework,
>>>>> so make sure those are installed on your system. The value tool
>>>>> plugin requires pyqwt5 as well.
>>>> Note: my Qgis binaries include a bundled pyqwt5.  I do this
>>>> because they are meant to be installed inside the PyQt folder, it
>>>> wouldn't work to install PyQwt5 in your system site-packages.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> Theory of the Universe
>> There is a theory which states that if ever anyone discovers
>> exactly what the universe is for and why it is here, it will
>> instantly disappear and be replaced by something even more
>> bizarrely inexplicable.  There is another theory which states that
>> this has already happened.
>> -Hitchhiker's Guide to the Galaxy 2nd season intro
> Qgis-developer mailing list
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
