[Qgis-developer] Mapfile Plugin
Mathias Walker
mwa at sourcepole.ch
Tue Oct 6 05:39:47 EDT 2009
Hello John
According to your traceback the mapscript module has been loaded.
What projection are you using in your mapfile? The mapfile plugin always
requests the image as WGS84 at the moment, so this could be the cause of the
error.
You can try rendering the mapfile from a console and see if you still get the
error:
Best regards
Mathias Walker
Sourcepole - Linux & Open Source Solutions
Elestastr. 18 7310 Bad Ragaz Switzerland
Tel: 081 330 77 11 Fax: 081 330 77 12
mwa at sourcepole.ch http://www.sourcepole.ch
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091006/a3e4d34a/attachment.bin
