[Qgis-developer] interpolation
Paolo Cavallini cavallini at faunalia.it
Wed Oct 7 07:17:37 EDT 2009
Marco Hugentobler ha scritto:
> I think you are right. The interpolation plugin calculated the values in the
> top left corner instead of the center of the raster cells. r11759 is supposed
> to fix this. Could you test if it works now?
Much more similar now. Still not identical though, but I guess this may be due to
rounding or other. If you want I can send you the two resulting rasters and the
sample data.
All the best, and many thanks!
Paolo Cavallini: http://www.faunalia.it/pc
