[Qgis-developer] INterpolation plugin: lines structure and break
lines?
Marco Hugentobler
marco at hugis.net
Mon Oct 12 01:45:06 EDT 2009
Hi Paolo
Structure lines and break lines are considered in the generation of the TIN
(IDW, by its nature, cannot consider linear elements).
Lets say you have elevation data that you want to be on the digital surface
(lake borders, contour lines, valley lines, ...). The code modifies the
triangulation such that no edge crosses a structure / break lines (known as
constrained delaunay triangulation).
The difference between break- and structure lines is that the first means a
sudden change in slope (where the surface is not continuously differentiable)
and the second a slow change. At the moment, in the interpolation plugin,
there is only linear interpolation for TINs and it behaves the same in both
cases. I have some code from my phd that provides cubic interpolation an that
makes a difference. I plan to bring this code into the interpolation plugin,
but it uses some old Qt3 container classes and therefore needs cleanup (maybe
at the hackfest ;-) ).
For an easy introduction to the subject, see my phd (or some of the references
listed): http://www.dissertationen.unizh.ch/2004/hugentobler/diss.pdf
Regards,
Marco
Am Freitag, 9. Oktober 2009 16.35:04 schrieb Paolo Cavallini:
> Hi all (especially Marco).
> I do not understand whet is the meaning of the above mentioned options for
> interpolation. Is there some documentation?
> All the best.
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
