[Qgis-developer] Fwd: Re: MultiQML plugin on MacOS X
Alex Mandel tech_dev at wildintellect.com
Wed Oct 14 19:33:56 EDT 2009
To follow up on that windowsflags seems to be what we're looking for.
Unfortunately different window managers: Aqua, XFCE, Gnome etc all do
things a little differently.
I found http://qt.nokia.com/doc/4.5/widgets-windowflags.html
But haven't figured out where to change those in the qt designer yet.
Alex
Alex Mandel wrote:
> You might need to make the window NonModal in the QDialog properties,
> but the best solution is to probably add a command button to cancel the
> window.
> Alex
> Maxim Dubinin wrote:
>> Hi all,
>> Need a hint with python programming for plugin on Mac. MultiQML user complained about
>> missing close button (attached) in About window, but in Win [1] it's all
>> fine. Unfortunately, I've no experience with Macs.
>> Any suggestion how this can be fixed?
>> Maxim
>> [1] http://gis-lab.info/images/screenshots/20091013-t30-17kb.jpg
>>> TDL> when I open the about-window of the plugin, there is no way to close
>>> TDL> this window and I have to force quit QGIS to clos the about window.
>>> TDL> Should be nice if you added a close button in the about window.
>>> TDL> Tomas
> Qgis-developer mailing list
