[Qgis-developer] grid tab does not dock
Marco Hugentobler
marco at hugis.net
Thu Oct 15 02:54:39 EDT 2009
Hi Borys
I'm not sure about the third tab. Because the 'entry' tab always refers to the
active composer item. So it might be confusing to users if a third tab appears
for composer maps only.
What about a separate dialog (accessible with a push button) for composer grid
settings? Or other ideas how to deal with limited space in the 'entry' tabs?
Regards,
Marco
Am Mittwoch, 14. Oktober 2009 18.04:20 schrieb Borys Jurgiel:
> Dne středa 14 října 2009 17:45:38 Paolo Cavallini napsal(a):
> > Hi all.
> > On r11800, the grid tab in the print composer is floating around, and I
> > cannot dock it anywhere. If I double-click on the head, it gets docked
> > *over* object properties. Should I fill a ticket? Should I send a
> > screenshot?
> I have the same problem - there is just not enough place to move the
> properties down. Marco, what about a third tab?
> Qgis-developer mailing list
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
