[Qgis-developer] Can not load a shp file with QgsVectorLayer
Martin Dobias
wonder.sk at gmail.com
Fri Oct 16 05:38:52 EDT 2009
On Fri, Oct 16, 2009 at 10:59 AM, Lutfi Oduncuoglu
<lutfioduncuoglu at gmail.com> wrote:
> vlayer = QgsVectorLayer( fileName, "hebe", "ogr")
> provider = vlayer.dataProvider()
> feat = QgsFeature()
> allAttrs = provider.attributeIndexes()
> provider.select(allAttrs)
> while provider.nextFeature(feat):
> geom = feat.geometry()
> print "Feature ID %d: " % feat.id()
> This piece of code returns nothing to me. What is wrong here.
Hi
first of all you should check whether the vector layer has been opened
correctly - this is the most common problem:
if not vlayer.isValid():
print "Couldn't open the layer"
If the layer is valid and it still doesn't print anything, try doing
some checks - find out feature count etc.
Regards
Martin
