[Qgis-developer] Discussing a forms-builder at the Hackfest
Jürgen E. Fischer
jef at norbit.de
Fri Oct 16 10:37:45 EDT 2009
Hi Andreas,
On Fri, 16. Oct 2009 at 13:34:00 +0200, Andreas Neumann wrote:
> flexible forms
> If you think there is room for a discussion on forms at the Hackfest in
> Vienna, I would make an entry at the Wikipage of the Hackfest.
+1 from me.
My idea would be the ability to assign a ui file to each vector layer.
This could be created using designer (there are also designer classes that
could probably be integrated into QGIS). The widgets on the form should be
named like the attributes and have a type corresponding to the edit type. That
form can then be loaded instead of the attribute dialog, but be initialized the
same.
We also discussed table joins, which would also fit in there (e.g. load foreign
keys from a table instead of a value map).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
