[Qgis-developer] Error after Upgrade to Ubuntu 9.10
Alex Mandel
tech_dev at wildintellect.com
Fri Oct 16 11:40:37 EDT 2009
Yes, it is most likely that the package will be updated when karmic is
released and the chance of SIP changing again has gone away.
In the future keep in mind that unreleased versions of Ubuntu still in
the pipes probably will have similar issues with QGIS and many other
apps out there.
Thanks,
Alex
Matthew Denno wrote:
> Francesco,
> Thanks for your response.
> So, do you think that the karmic repositories will eventually be updated to
> work with the the version of sip that ships with karmic?
> I don't need python support right now so if it will probably be updated in
> the near future I will just wait.
> Thanks again.
> Matt
> On Fri, Oct 16, 2009 at 4:21 AM, Francesco P. Lovergine <
> f.lovergine at ba.issia.cnr.it> wrote:
>> On Thu, Oct 15, 2009 at 11:19:51PM -0400, Matthew Denno wrote:
>>> Hello All,
>>> I just upgraded to Ubuntu 9.10 beta and also upgraded from QGIS 1.2 to
>>> QGIS to 1.3 from:
>>> http://ppa.launchpad.net/qgis/unstable/ubuntu karmic main
>>> Now I am receiving the following error when QGIS starts:
>>> Couldn't load PyQGIS.
>>> Python support will be disabled.
>>> Traceback (most recent call last):
>>> File "", line 1, in
>>> RuntimeError: the sip module implements API v6.0 but the qgis.core
>>> module requires API v5.0
>>> Python version:
>>> 2.6.4rc1 (r264rc1:75270, Oct 13 2009, 17:19:38)
>>> [GCC 4.4.1]
>> AFAIK you need to rebuild (no source changes) against current sip.
