[Qgis-developer] Composer grid issue
John C. Tull jctull at gmail.com
Tue Oct 20 13:27:53 EDT 2009
Hi Marco,
As always, thanks for your great work and progress on the composer!
I'll look forward to testing your changes.
Cheers,
John
On Oct 19, 2009, at 11:26 PM, Marco Hugentobler wrote:
> Hi John
> Thank you for reporting. I'm currently implementing the possibility
> to rotate
> the composer map and this changes a lot in the composer grid code.
> Therefore,
> I'm going to address this issue after the rotation code is in trunk.
> Regards,
> Marco
> Am Montag, 19. Oktober 2009 22.44:56 schrieb John C. Tull:
>> Marco,
>> I was excited to see the new map composer grid feature. I tried it
>> out
>> on some field maps last week and found out that the grids were not
>> accurate. I believe you might be able to reproduce an error with the
>> attached test file. It appears to be a dpi issue, for some reason.
>> Here are my steps:
>> 1) Open a new qgis canvas and add the attached shapefile.
>> 2) Verify that the projection (CRS) is set to epsg 26911 for the
>> project.
>> 3) Zoom in to a subset of the grid at approximately 1:100000 scale.
>> 4) Open the map composer and add the map canvas to the composer
>> canvas.
>> 5) Turn on the composer grid with a 5000x5000 spacing.
>> 6) Now, zoom in the map composer 4 or 5 times.
>> 7) With the map layer selected, update the preview and note the
>> offset
>> between the two grids.
>> 8) Output a png image at 300 dpi (should look correct).
>> 9) Output a png image at 200 dpi (the offset should show).
>> On another note, it would be nice to be able to suppress the
>> scientific notation of the grid labels. In the UTM example I have,
>> the
>> scientific notation is actually a larger label than the full integer
>> value.
>> Cheers,
>> John
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Webereistrasse 66
> CH-8134 Adliswil
> marco at hugis.net
> http://homepage.hispeed.ch/hugis
